| | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Any pros or cons on using a 5 speed transmission from an '89 1500 behind a 250 6 cyl? Is it an easy swap for a TF truck? Any problems with hooking up a speedometer? It's a 2 hr drive for me to see it so I'd like to know if it's worth a trip. Any insight will be appreciated.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Since my original post I've found info that this is probably an NV3500. Searching the forums on this gave me some info that has convinced me to let this one pass. I've got an MY6 and a couple of 3 sp OD's in my collection that I think will be easier to work with. If anyone feels I'm making a mistake I'd be interested in hearing your opinions. Thanks.
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | The NV3500 is a good trans for the 250 engine. They are not made for a higher torque installation but the 250 would be a great combination with the NV3500. I'm using a Getrag 5 speed from a 1992 GMC with a 350 engine behind my built up 292 with around 350 ft. lbs. and 350 H.P. in a 1932 Chevrolet pickup. The Getrag is stronger than the NV3500 but not quite as strong as the NV4500. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The speedo will be a problem as it probably has an electronic drive. The NV3500 has a built in bell housing & uses a hydraulic clutch release. It wont fit the old 235 engines. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
