1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Over the weekend I found my brackets for back-up lights on the SM420 in my 48 3100. I need to push down on the cover at the top of the shifter rod and turn it to replace it. Is there a trick to that? Do I need to take the cover off the transmission to remove this plate?
Thanks.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Push down, turn about 1/8 turn counter-clockwise, it should pop up. If it's really crusty, soak it good with a penetrating oil like PB blaster or WD-40. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 |
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | how does the back-up light switch mount? you wrote that you found brackets and that you need to get the shifter out. I have not seen that before (for a SM420). How does it work? Thanks
Professional Novice
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah Dennis, how does that work???? I've never seen a backup light accessory for an AD truck with an SM420 trans. From you post it sounds like there is something inside the transmission??? Pictures please.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | IIRC, there's a bracket that mounts to the shift lever with a push-to-contact switch on it, or a switch on the shifter housing and an operating lever that's attached to the stick. Pretty primitive, but it works. They were a very scarce option. Jerry
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Jerry hit it. The bracket I spoke of replaces the cap at where the shifter rod goes into the top of the transmission. It has a tab where the push-button contact mounts. Then there is a paddle bracket that mounts to the shifter rod. When the transmission is shifted into reverse the paddle bracket pushes down the contact and the back up lights come on. Simple contraption.
I bought the whole system years ago and put the column set-up on my 55 TF. I will put this system on my 48 with the floor shift (SM420).
It is pretty neat. Now I need to find 2 back-up lights from the early 50s car.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Pardon my dumb but I still can't picture what your discribing, sure appreciate a photo. DG
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, it would be interesting to see a photo of an original SM420 backup switch? Novak Transmissions website: "The last year of the SM420 (1967 [maybe 66 & 67]) had a backup light switch installed in the top cover to meet that year's federal mandates." Novak installs a switch on their transmission rebuilds but it does not look like they sell a kit for others to install. Maybe they install a conversion as described below. Old Stovebolt.com thread on adding a back-up lights switch. Here's another conversion. | | | | | Joined: Jun 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 46 | | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | Maybe a dumb question, but what's an SM420 transmission? Might that be the four speed that is in my '39 3/4 ton?
Gary | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | SM420 is the 4-speed GM started putting in trucks in 1948 and used through 1967. It might be the one in your '39 but only if someone has performed a swap.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | OldSub
OK. I think mine is the original '39 transmission. Putting in the backup light switch is still an interesting project, and may well work on the old box, too.
Gary Fossen | | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | Just dug up this old thread...and have a question about the switch needed for this set-up. I have the bracket, and depressor paddle piece, but lack the actual switch. Does anyone know of a replacement switch that will work? I have found NOS ones, but they are too rich for my blood ($100.00) I'm sure there is an aftermarket switch out there that would work, but not sure where to find one. To make matters worse, I don't have the original one to use as a comparison. Has anyone encountered this problem, and can you hook me up with the part #???? Thanks! | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | A push-to-start button should work, if you can figure a way to mount it to the shift lever. Any good FLAPS should have a listing for a generic starter switch, or one of the aftermarket suppliers like Cole-Hersee will definitely list one. Try a boat shop or a marina if necessary for a push-button horn switch- - - -same thing. Jerry
| | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | A push start button is a good idea, but I'm not sure it would have the correct amount of reach?? It is something to consider however, and I will look into it. | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | I'm still here, but a long way from the backup switch. I'm in the process of painting the cab, and that seems to be a rather steep learning curve...considering it's my first. Just the same, thanks for the responses.
Gary | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | Something just occurred to me...I think there are spring loaded toggles available, too. The longer paddle would make them somewhat adjustable for length of throw... | | |
