4 members (1955 1 Series, HandyAndy, Ponchogl, carbking), 88 guests, and 1 robot.
Topics128,113
Posts1,056,619
Members48,450
Okay I am stuck. When I got my truck the oil pressure gauge was never hooked up. I have searched the web over the past few days trying to see where I pick up my oil pressure connection on the engine to the gauge. Not finding a lot of anything. The motor is actually a 42, 216.
[IMG]http://i111.photobucket.com/albums/n142/DCINSC/37%20CHEVY%20REBUILD/DSC08506.jpg[/IMG]
1937 Chevy 1/2-Ton
Behind the spring that's hanging down off the throttle linkage in your picture, there's a plugged port. The oil pressure gauge attaches there. If you choose to install an oil filter, the supply line to the filter attaches at the same spot, by using a T fitting. To the lower left of the sheet metal oil distributor plate, there's another fitting for the oil filter return line.
Thanks Hotrod Lincoln, Better to be sure than not. I don't plan on running an oil filter. I have read that they are pretty much useless with low pressure systems and I am real religious about oil changes.
1937 Chevy 1/2-Ton
Actually, the bypass filter does a better job of straining the gunk out of the oil than a full-flow because the filter element can have a tighter weave. It doesn't have to pass enough oil to keep the bearings lubed. The oil just gets filtered a little at a time instead of all the oil going to the bearings getting strained before it gets there. An ideal system would be a full-flow filter to catch the rocks, marbles, and big chunks, and a bypass filter to really clean things up. Cummins and most Detroit diesel engines are set up that way.
Thanks I will make note of that by printing your reply.
1937 Chevy 1/2-Ton
yes the filter does a better job of filtering the 5% or so of the oil that actually makes it through the filter the problem lies with the 95% that doesn't go through the filter. ( I may have my percentages off, but the problem is the same)
About 5% of the oil might make it to/through the by-pass filter as the oil circulates through the lubrication system (5% of the oil that passes by the port to the filter cansiter). However, over time, 100% of the oil will eventually go through the by-pass filter canister.
Ex Hall Monitor
Ex Hall Monitor
