0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 3 New Guy | | New Guy Joined: Feb 2011 Posts: 3 | The man that I bought my truck from has done some welding on the body of my truck, and it looks more like glob weld than anything else. i need to remove it so that i can re do the weld, but i am not sure of how to do so? What would be the simplest way of removing all of this weld? cutting it out and replacing it? Or what? I don't know what would be the easiest. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | not an "easy way", other than the rotary welding eraser, although some of us might wish there was! if you can't grind it off you probably will have to cut and replace
Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The type of grinder & grinding wheel you use depends on the location you need to grind. Generally you use a course abrasive and go slow to prevent a lot of heat build up.
| | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 66 | I know what you going through, someone did the same on my 35, Im using a coarse grinding wheel on the heavy welds then a finer one as I get close to the body. you dont want to cut the body steel to thin, I will even use a hand file so I can control the cut, just watch the heat. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | One more way to remove weld is get a few flap sanding disks from a hardware store they come in differant grits and they don't hold the heat as much.I use them in my 4inch angle grinder on lower speed and also have the 2inch type for my small air grinder to get in tight spots you can get some 80 grit to get close than use some 240 grit for a nice smooth finish.
Pete | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 |
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
