1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#720748 02/13/2011 8:41 PM
The man that I bought my truck from has done some welding on the body of my truck, and it looks more like glob weld than anything else. i need to remove it so that i can re do the weld, but i am not sure of how to do so? What would be the simplest way of removing all of this weld? cutting it out and replacing it? Or what? I don't know what would be the easiest.
not an "easy way", other than the rotary welding eraser, although some of us might wish there was!
if you can't grind it off you probably will have to cut and replace
squeeze #720766 02/13/2011 10:04 PM
Ex Hall Monitor
Ex Hall Monitor
The type of grinder & grinding wheel you use depends on the location you need to grind. Generally you use a course abrasive and go slow to prevent a lot of heat build up.
Tiny #720819 02/14/2011 1:20 AM
I know what you going through, someone did the same on my 35, Im using a coarse grinding wheel on the heavy welds then a finer one as I get close to the body. you dont want to cut the body steel to thin, I will even use a hand file so I can control the cut, just watch the heat.
Glen M #720943 02/14/2011 1:54 PM
One more way to remove weld is get a few flap sanding disks from a hardware store they come in differant grits and they don't hold the heat as much.I use them in my 4inch angle grinder on lower speed and also have the 2inch type for my small air grinder to get in tight spots you can get some 80 grit to get close than use some 240 grit for a nice smooth finish.
Pete
Pete52 #721133 02/15/2011 3:04 AM
What Pete said... ditto.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
