7 members (Oswald, FAST55, Ponchogl, 2-Ton, Oldcaliforniakid, Hotrod Lincoln, Donf),
74
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I tried the search engine, but only came up with EXterior patch panels. I am wondering if anyone makes a cardboard or fiberglass panel to cover the braces on the INterior of the truck back. I took out the fuel tank and want to finish it off nicely. Any ideas or contacts? Was there anything like that originally?
Thanks!
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | The upholstery shop in Texas that did mine attached snaps to the rail running round the cab at the top of the seat and made a nice skirt out of the same material that covers the seat and its snaps off for cleaning. the back of the cab ...looks nice IMO.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | American classic parts sells a seat back for a 1950 Part number UP801American Classic sponsors this forum Other Vendors carry that part also Good Luck | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | Thanks for the ideas and links!
Radial, Did your upholstery shop put a rigid back on the piece or is it just material that is pulled tight with the snaps. I like the idea of being able to clean it since this will be a work truck.
Craig
CK
