| | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello, I have one questions again, when I fix the felt channel into the door frame, must be before the door window installed or can I fix at first the felt channel in the door frame and then install the window? Ask Wolfgang | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | wokri, when I did mine with the door laying back side up I used 3-M's black adhesive and set the channel, then by hand pushed the window up into the channel and layed a nice thick beach towel on the glass and then put 10 lb. of weight on the glass to hold it down nice an tight till the 3-M setup over 24 hrs. then I removed the window glass and did my riveting. came out very nice.
