0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
Hello,
I have one questions again, when I fix the felt channel into the door frame, must be before the door window installed or can I fix at first the felt channel in the door frame and then install the window?
Ask
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
wokri,
when I did mine with the door laying back side up I used 3-M's black adhesive and set the channel, then by hand pushed the window up into the channel and layed a nice thick beach towel on the glass and then put 10 lb. of weight on the glass to hold it down nice an tight till the 3-M setup over 24 hrs. then I removed the window glass and did my riveting.
came out very nice.
1952 Chevy Shortbed
Photos in Photobucket
