7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible), 125 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#720742 02/13/2011 8:18 PM
anyone know where the hand throttle connects on the carb on a 235 1959 3100?
phnman23 #720746 02/13/2011 8:41 PM
like this ... if you didn't have one [wasn't always on by 59], you probably don't have that necessary bracket or the little trick screw clamp that allows it to slide in the throttle rod hole, you'll need to find them
squeeze #720753 02/13/2011 9:09 PM
have the bracket and stole the cable clamp off the choke of an old carb.Thats kind of what i thougt but when you press the accelerator pedal isn't it going to push the throttle knob out inside the cab?
phnman23 #720754 02/13/2011 9:09 PM
thanks by the way
phnman23 #720765 02/13/2011 9:59 PM
Ex Hall Monitor
Ex Hall Monitor
If you look closely the cable wire is passing through a hole in the linkage. As the foot feed is pressed the linkage slides up and down the wire without moving it. The clamp on the end Bill referred to is called a wire or cable stop. It simply clamps to the wire to keep it from pulling through the hole in the linkage when you pull the knob. The set up is a bit more obvious on my '38.
Tiny #720770 02/13/2011 10:17 PM
further on what Tiny sez, the cable pulls the linkage rod to increase throttle and maintain that as a minimum, if you then push the pedal it opens the carb more without affecting the hand cable position .... looking at it from the other direction, the hand throttle prevents the foot feed from coming all the way back to idle, so it doesn't act like modern cruise control, the use of the foot feed doesn't affect it
squeeze #720774 02/13/2011 10:27 PM
If you don't have a cable stop, the brass screw fitting from inside an electrical connector will work.
1951 1 Ton Completed
truckernix #720829 02/14/2011 1:42 AM
I can see it better on the pic of your 38. the flange were the accelerator rod connects does not have the tab on it like yours for the cable to pass through.Hmmm?
phnman23 #720837 02/14/2011 2:10 AM
the original arrangement [for the TF years anyway] was for the cable to go thru the cotter pin hole in the linkage rod end - and there was a sheet metal keeper as shown in my pic [has an extension with clip 'fingers' around the straight part of the rod] that prevented things from rattling around or binding
squeeze #720897 02/14/2011 5:17 AM
on my truck, the cable end is formed into a big U that pulls up on the linkage, it's open at the top so the gas pedal works unobstructed....
GMC: Get More Cash...
1958 GMC
My Webshots photos
