0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | anyone know where the hand throttle connects on the carb on a 235 1959 3100? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | like this ... if you didn't have one [wasn't always on by 59], you probably don't have that necessary bracket or the little trick screw clamp that allows it to slide in the throttle rod hole, you'll need to find them Bill | | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | have the bracket and stole the cable clamp off the choke of an old carb.Thats kind of what i thougt but when you press the accelerator pedal isn't it going to push the throttle knob out inside the cab? | | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you look closely the cable wire is passing through a hole in the linkage. As the foot feed is pressed the linkage slides up and down the wire without moving it. The clamp on the end Bill referred to is called a wire or cable stop. It simply clamps to the wire to keep it from pulling through the hole in the linkage when you pull the knob. The set up is a bit more obvious on my '38.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | further on what Tiny sez, the cable pulls the linkage rod to increase throttle and maintain that as a minimum, if you then push the pedal it opens the carb more without affecting the hand cable position .... looking at it from the other direction, the hand throttle prevents the foot feed from coming all the way back to idle, so it doesn't act like modern cruise control, the use of the foot feed doesn't affect it
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you don't have a cable stop, the brass screw fitting from inside an electrical connector will work. | | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | I can see it better on the pic of your 38. the flange were the accelerator rod connects does not have the tab on it like yours for the cable to pass through.Hmmm? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the original arrangement [for the TF years anyway] was for the cable to go thru the cotter pin hole in the linkage rod end - and there was a sheet metal keeper as shown in my pic [has an extension with clip 'fingers' around the straight part of the rod] that prevented things from rattling around or binding
Bill | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | on my truck, the cable end is formed into a big U that pulls up on the linkage, it's open at the top so the gas pedal works unobstructed.... | | |
