1 members (51sub),
128
Mod | | | Forums66 Topics128,125 Posts1,056,338 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Ben search-en can't find what I'm looking for.I've got 2.41 gears and need to know what other gears I can use on this 8.5" carrier. or lead me to a web site on 8.5" 10 bolts Please. I think there are 3 different off sets.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Oct 2010 Posts: 6 New Guy | | New Guy Joined: Oct 2010 Posts: 6 | If you want to use a lower gear with the carrier you have, you will need to get a ring gear spacer. They are readily available.
1955 5-Window First Series Chevy 1996 SVT Mystic Cobra 2010 Silverado LTZ Crew Cab
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Ring gear spacer? Are they a good option?
| | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | Or you can use a gear set with a thick ring gear. There are gear sets available that use a thicker ring gear that allows you to use your existing carrier. | | | | | Joined: Feb 2000 Posts: 5,221 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,221 | Spacers are work fine, we used them for years before the thicker gears came out. Its a cheap way around not buying a new center section.
Joe | | | | | Joined: Oct 2010 Posts: 6 New Guy | | New Guy Joined: Oct 2010 Posts: 6 | Any of the big name retailers (Summit, etc.) will have them in their gearing section. If I remember right, they are .200" thick. I don't know which is cheaper, spacer or thick gears. I have a 8.5" 10 bolt with a posi carrier that uses the spacer.
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Thanks for all the info Guys, Exactly what I was looking for.
| | | | | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | If you need to retain a 6 lug axle then a 73-mid 80's Chevy 1/2 or Blazer 4x4 rear axle will work.Just saw a thread on another site of the swap.The Blazer axle is 64 inches wide and the stock 50 is 62 inches by actual measurement.The slight difference of an inch on each side won't matter. | | |
