0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | Okay I am stuck. When I got my truck the oil pressure gauge was never hooked up. I have searched the web over the past few days trying to see where I pick up my oil pressure connection on the engine to the gauge. Not finding a lot of anything. The motor is actually a 42, 216. [IMG] http://i111.photobucket.com/albums/n142/DCINSC/37%20CHEVY%20REBUILD/DSC08506.jpg[/IMG] | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Behind the spring that's hanging down off the throttle linkage in your picture, there's a plugged port. The oil pressure gauge attaches there. If you choose to install an oil filter, the supply line to the filter attaches at the same spot, by using a T fitting. To the lower left of the sheet metal oil distributor plate, there's another fitting for the oil filter return line. Jerry
| | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | Thanks Hotrod Lincoln, Better to be sure than not. I don't plan on running an oil filter. I have read that they are pretty much useless with low pressure systems and I am real religious about oil changes. | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Actually, the bypass filter does a better job of straining the gunk out of the oil than a full-flow because the filter element can have a tighter weave. It doesn't have to pass enough oil to keep the bearings lubed. The oil just gets filtered a little at a time instead of all the oil going to the bearings getting strained before it gets there. An ideal system would be a full-flow filter to catch the rocks, marbles, and big chunks, and a bypass filter to really clean things up. Cummins and most Detroit diesel engines are set up that way. Jerry
| | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | Thanks I will make note of that by printing your reply. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | yes the filter does a better job of filtering the 5% or so of the oil that actually makes it through the filter the problem lies with the 95% that doesn't go through the filter. ( I may have my percentages off, but the problem is the same) | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | yes the filter does a better job of filtering the 5% or so of the oil that actually makes it through the filter the problem lies with the 95% that doesn't go through the filter. ( I may have my percentages off, but the problem is the same) About 5% of the oil might make it to/through the by-pass filter as the oil circulates through the lubrication system (5% of the oil that passes by the port to the filter cansiter). However, over time, 100% of the oil will eventually go through the by-pass filter canister. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
