2 members (Peggy M, Simso),
291
9
Mod | | | Forums66 Topics128,077 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | My old Willys has been upped to 12v. I purchased a 12v gas gauge and asked my supplier to sell me a 12v sending unit. He said I don't need one, that only the gauge needs to be upped from 6 to 12. Does this sound correct?
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes ... the sender is just a variable resistor, voltage insensitive - if the 12v gauge has a much different resistance range than the 6v, then you'd need a sender with a matching range, or if not much different, live with a minor mental correction - likely won't be anything noticeable
Bill | | |
