2 members (klhansen, Otto Skorzeny), 86 guests, and 4 robots.
Topics128,130
Posts1,056,712
Members48,454
do i need to replace the original crossmember on my 59 apache 3100 since i am going with a 700r4 automatic transmission. i would like to hear from members who have done this conversion to see what i am getting into. thanks,jimbo
FOR EVERY PURCHASE MADE BY A BOLTER I CONTRIBUTE BACK TO THE STOVEBOLT SITE.KEEP ME IN MIND FOR YOUR 47-59 ORIGINAL CHEVY TRUCK PARTS NEEDS. THANKS,JIMBO MY CELL NO. 817-648-3249 "SOME OLD CHEVY TRUCKS MUST DIE SO THAT OTHERS CAN LIVE"
yes you need a trans support crossmember for any automatic, they can't hang off the engine the way the manual trans did - there is none under either original manual trans - they're available from vendors, or fab yer own
Hey Bill What about Motor mounts? You don't want to mount the hole drive train from the ends. Don't you also have to change to side motor mounts?
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
if you have the original 283V8 front peg style mounts, then yes, you need to change to the side mounts, but most folks do that anyway on non-stock V8 installs - also you hafta actually notch or remove the original rear crossmember for a modern auto trans to fit without problems
I looked at putting a NP A833 4spd with the heavy iron case in a TF with the front mounts, and figured it would work to fab up a thin sheet steel piece to put between the bellhouse and block that had ears to replace the mounts on the old bellhouse ... might work with an auto too, but I'm not sure how adding that 1/4" space would affect things ohwell
Thanx Bill
"I looked at putting a NP A833 4spd with the heavy iron case in a TF with the front mounts, and figured it would work to fab up a thin sheet steel piece to put between the bellhouse and block that had ears to replace the mounts on the old bellhouse ... might work with an auto too, but I'm not sure how adding that 1/4" space would affect things" Bill
I see no problem with that if a guy put the same size spacers between the flexplate and the torque converter
Grant
user
so any chevy automatic transmission crossmember will work??? will one from a 67-72 chevy work.i am putting a 68 430 buick big block in it. i know i will have to change to side mounts on the motor. thanks for the helpful info.
Jim - the 55-50 and 67-72 frames are very different, but you could prolly adapt it ... more common is the universal style tube piece available from the vendors
THANKS BILL
GOT ONE TODAY FROM LMC TRUCK. 60.00 NOT A BAD PRICE. THANKS GUYS FOR ALL YOUR HELP.
Not sure if that helps. It´s not a auto tranny but with the OD I run in the same problems on the 41 Sedan and ended up to fab my own "sub crossmember". Just to give you an Idea:
http://img154.imageshack.us/img154/6408/bild0852fp.jpg
http://img154.imageshack.us/img154/6792/bild0826wc.jpg
http://img154.imageshack.us/img154/4481/bild0877dh.jpg
The rubber mount is (I confess it) of a 1943 Jeep.
Frank
