| | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71922 01/19/2007 3:56 AM | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | I have a 39 GMC, and I believe it has a Chevy 4 speed transmission. I bought a new speeodometer cable w/housing for a GMC. The cable has square ends and fits in the speeodometer fine.
It doesn't turn. I removed the part on the transmission the cable housing screws to. It appears there may be some sort of adapter missing to turn the cable.
Now my question.. Could the Chevrolet have a different style cable?
Is there some type of adapter missing?
Maybe some one can lend some insight on this issue. I tried looking in the parts book, but can't seem to identify anything other than the seedo gear. Thank you, Jim
Jim
#71923 01/19/2007 4:55 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Jim:
I have the same tranny (albeit a touch newer) and have the same problem -- but with a stock cable.
I'm pretty sure that the nylon gear on my drive unit is shot. Have you checked for movement on the drive unit? Another way is to pull the yoke and the rear seal and inspect the drive unit for damage. | | |
#71924 01/19/2007 10:31 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Chev. & GMC should be the same. If you screw the part in the trans. out there should be a shaft with a gear on the end. That gear meshes with a gear in the trans. on the output shaft like Brendan say,s. Raise the rear wheels & put a small screwdriver in the hole where the cable goes in. Turn the driveshaft & the screwdriver should turn. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#71925 01/20/2007 3:05 PM | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | Thanks for the INFO.
I ensured the speedometer was working with an electric drill, it does.
I removed the adapter on the transmission (with a one inch wrench). Spun the rear wheels and the part turns.
The part I saw turn looks like a 3/8" tube with a slot in it.
There must be something missing.
Dont know what it looks like or where to obtain one.
thanks, Jim
Jim
#71926 01/23/2007 5:50 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Can you post a picture? Someone may know what the part is if he can see what you're working with. | | |
