Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (mo2cyl, Rusty Heaps), 59 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#718985 02/07/2011 3:42 PM
SPL
Offline
My chev, 235, 6cyl.has been rebuilt and I have started it up. All runs great except a "thumping" noise at the base of the distributor. The dist. went in fine with the gear and tang matching good. My question is, is there an o- ring or round gasket that seats at the base of the dist.where it goes into the block? My shop manual doesn't say anything about one. Thanks.
SPL #718989 02/07/2011 4:07 PM
The one I purchased from Napa for my 235 it came with an o-ring.
...pic..click..
I dont know if the missing o ring is related to your "thumping" noise.
I installed the distributor without the o-ring.
You may need to investigate.
Good Luck
DADS50 #718997 02/07/2011 4:22 PM
SPL
Offline
Thanks for you reply.Why did you not use the oring?
SPL #719003 02/07/2011 4:37 PM
I couldnt get it to drop in with the o-ring on.
May be who ever rebuit the dist used to thick of a cross section o ring
The one I replaced didnt have the o ring installed either.
I have not experienced any problems so far.
If I do Ill look for a replacement o ring
Good Luck
DADS50 #719011 02/07/2011 5:18 PM
There was no O ring used originally.
If there is noise coming from the distributor I would check the mechanical advance under the points plate.
My Blog
Pre '68 Dave #719065 02/07/2011 9:33 PM
SPL
Offline
Thanks for the advice.I will have to get my dist. diagram out to figure out what you mean.I'm not a pro at this stuff.What would I be looking for under the point plate?
SPL #719079 02/07/2011 10:39 PM
tclederman #719085 02/07/2011 11:02 PM
To go along with the exploded view in the parts manual are the distributor overhaul instructions in the shop manual.
Is the "thumping" sound coming fro the body of the distributor? Or, from the area where the distributor enters the block?
Hoyt
Hoyt
hoyt #719359 02/08/2011 8:46 PM
SPL
Offline
I checked on your question and the thump or knock is both at the base of the distributor where it enters the block and anywhere else you put your listening stick on the body and cap of the distributor. The guy who rebuilt the engine (been at it for 30 years and known to be very honest) said the noise really puzzles him.
