4 members (jmoore, Gray_Ghost, Otto Skorzeny, 2-Ton), 81 guests, and 1 robot.
Topics128,050
Posts1,055,646
#71902 01/19/2007 1:47 AM
I would like to hear from someone who has swapped a 235 into an 31 !/2 ton. This is my first vehicle of this vintage and I need more info. How does the 235 compare to the original engine as far as size and and motor/tranny mounts? Anything would be helpful. Thanks
#71903 01/19/2007 2:08 AM
The original 194 C.I. engine is actually longer than the 235. You would want to use the 216 type front motor mount and an early 40's truck bellhousing and mounts, I think. Do a search on 194 or 207 engine swaps for more info.
#71904 01/27/2007 3:33 AM
for "Fortynine5"
I am building a 1930 Ford Truck with a 261 in it.
You can find some pictures of it and my old Stromberg BXOV carbs at,
http://community.webshots.com/user/OldFartEd
If you have any questions or anything just e-mail me, I would be more than glad to shair anything I done or learned from building my project. Which is still in the 'mock-up stage'
