| | | Forums66 Topics128,083 Posts1,056,331 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Ok. So I have found one way to remove my oil bath air cleaner and that is to install a holley 1946 carb, Is there any other way to do this using the model B carb. Im thinking I may have to be the first to make an adapter for this. Thanks guys. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | ??? What does changing the carb have to do with removing the air cleaner? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It is a bit confusing. Are you asking how you can replace the oil bath with a dry element filter?
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I've got dry filters on both of mt B's. They are available for 1-bbl carbs but they're tiny, so I made an adapter to be able to use a 4-bbl air cleaner. Mr. Gasket offers a plastic adapter, but it's very flimsy, and crushes when the top wingnut is tightened. I got rough dimensions from it and made a 2-piece adapter from aluminum. Works good.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Feb 2004 Posts: 29,825 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,825 | Several people here have solved the alleged problem of oil bath filters by gutting out the filter housing and adapting a paper-element filter to the original-looking part. Most oil bath filters have two sections, a horsehair-filled pre-filter, and an oil reservoir to catch the heavy chunks as the air makes a 180-degree turn right over the oil on its way back up to the top of the filter housing. With routine maintenance, there's nothing at all wrong with an oil bath filter. Wash the woven part in solvent like mineral spirits or Diesel fuel, and change the oil in the filter at every engine oil change. Straight 30 weight works best in the filter. Jerry
| | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Sorry. the resone for replacing it is cause there is no way to hook a wing nut to it for a air filter. the oil bath tightens at the neck. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | You can install a dry element inside the original oil bath breather.If you do a search on it,you will find the part number for it.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2000 Posts: 5,224 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,224 | Look around at swap meets, I found two matching oil bath cleaners with wing-nut hold downs for a two carb intake I am working on. These came from Studebaker's I think, at least thats where I found replacement decals for them. I gutted them and installed dry furnace filter material.
One other option is to use a piece of exhaust tubing the same diameter as the carb top, then weld a cross piece over the top so you can wing-nut this adapter to the carb, then clamp the filter to the adapter. It will set a littler taller, but should work out pretty slick.
Joe | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Is your issue with the wingnut or the oil bath air filter?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | where do you get the stuff to make a oil bath into a dry element... | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | I picked up an 8" diameter by 2" tall element from my L.A.P.S. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I took an extra oil bath air cleaner, took out the filter element and cut the inner metal up to the point where it looked original but would allow the paper filter to operate. I took this whole assembly down to the Autozone and matched a paper filter. I don't remember the filter number but it was not that hard.
Best of luck
| | | | | Joined: Feb 2000 Posts: 5,224 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,224 | I just used 7 or 8 layers of filter material from the hardware store. I bought cheap house furnace filters and cut circles out of it to replace the horse hair. I figure no more then I drive a year, and a bunch of shoved in to place, it should be good to go.
Joe | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Cool thanks guys. I guess the real issue is the wing nut. Ill go up to Autozone and see what I can find to drop in. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | SVWILBUR, You still there? I am working to convert my 283 air cleaner to one with the K&N 3230 filter. Followed your threads and pictures. Question: Appears I need about 1 inch more height to get the correct profile. I presume you made that up with the double sided tape. Did you use something on the cap (mates to top of filter) to make up some profile or did all the height addition come from the base? How did the double sided tape hold up? Thinking of the grease as an option, but not sure I will be able to make up the additional height needed. Any follow on advice? Hambone | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | His last post was 3/25/12. You might send him an email if it's in his profile.
| | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | So are oil bath filters no good?, Are they suppose to have a prefilter?, Is a dry filter better?,Not trying to hijack this thread just confused. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | alltruck - oil bath filters are the best if properly cared for [especially in very dusty conditions], but many folks that don't really use the trucks don't like the "mess"
Bill | | | | | Joined: Jun 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 51 | alltruck - oil bath filters are the best if properly cared for [especially in very dusty conditions], but many folks that don't really use the trucks don't like the "mess"
Bill since I live on a dirt road, I should probably use the oil bath. Is it just changing the oil and using gas to clean the mesh the maintenance required? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, keep it clean and especially don't overfill, they work well
Bill | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Found on the NAPA site a listing of all their air filters by size, sorry don't have the link but it's out there. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I good news is, I have 2 air cleaners. One modified and one old style. As I work out the details of the paper filter set up, I intend to use the oil. I have heard the oil is a good way to go, minus the potential mess and emissions. Thanks for replies. | | |
