| | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | I have a 1954 3600 that had no heater. I found a restorable one (fresh air type) but it does not have the underdash bracket for the flexible cable that operates the inside/outside vertical door. It does have has the correct bracket for the temp control rod.
Question: any idea where to find a correct bracket for the flex cable that mounts left of the steering wheel? Or, Plan B, the temp control rod brackets seem more common. Can I adapt one of those to use for the flex cable?
Any help would be appreciated. Thanks.
Harry | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | I had the same issue. I found one on eBay. But you might want to post a request in the swap meet under "Truck Parts Wanted".
Welcome and good luck, Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | If you aren't in a hurry,Jim Carter is having both brackets reproduced and will be available next month sometime.Finding a original shouldn't be too hard,may just take some time.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
