4 members (Ridgeback, baldeagle, stlcardinalsguy, Peggy M), 43 guests, and 5 robots.
Topics128,012
Posts1,055,317
Members48,419
I have a 1954 3600 that had no heater. I found a restorable one (fresh air type) but it does not have the underdash bracket for the flexible cable that operates the inside/outside vertical door. It does have has the correct bracket for the temp control rod.
Question: any idea where to find a correct bracket for the flex cable that mounts left of the steering wheel? Or, Plan B, the temp control rod brackets seem more common. Can I adapt one of those to use for the flex cable?
Any help would be appreciated. Thanks.
Harry
I had the same issue. I found one on eBay. But you might want to post a request in the swap meet under "Truck Parts Wanted".
Welcome and good luck,
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
If you aren't in a hurry,Jim Carter is having both brackets reproduced and will be available next month sometime.Finding a original shouldn't be too hard,may just take some time.
Tim
1951 3100 Chevrolet
That's good news, Tim.
-Unknown-
Moderated by  ndkid275, Phak1
