8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC), 104 guests, and 1 robot.
Topics128,060
Posts1,055,838
Members48,427
#712823 01/18/2011 1:56 AM
Howdy all.
I am working on the cab of my '66 Chevy. The drip rail right above the firewall is really rusted, as seen in these pictures:
http://s140.photobucket.com/albums/r28/meld1234/Davids%20Truck/?action=view&current=IMG_3027.jpg
http://s140.photobucket.com/albums/r28/meld1234/Davids%20Truck/?action=view&current=IMG_3026.jpg
Its actually worse than it looks even. I was planning on welding a strip of metal over the damage, but after cleaning it up and looking closer it is extremely unlikely I will get a good weld, the surrounding metal is pretty nasty.
I am halfway considering laying in a strip of fiberglass, shaped like a "u" to allow a channel for water to run down, since this area does not appear to be structural and it is very unlikely I will get a water tight seal with a metal strip.
Any suggestions?
POR 15 and fiberglass mat would be a perfect solution for that.
1950 3804 Pickup
fiberglass sucks
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
Yes it does. You can use POR 15 and fiberglass mat and it is better than resin because you can put it over rust and it will stick and stop the rust as well as fill the hole. I agree that fiberglass resin and mat suck, but we aren't talking about that.
1950 3804 Pickup
This is off-topic but I like the train picture #16. Is there a story behind that?
Steve
man am i glad I live down south-never seen rust like that down here.
smaiocco-i have that same pic on my PC, IIRC it's somewhere in North Cali, back in the 60s.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I got that picture from the HAMB board, I don't know anything about it except that its in CA, I like to think my truck could be on there, she's a California girl....
i done mine that way, works great. That POR 15 is pricey but it does do the job.
OK, now I'm tracking. You guys mean to use teh POR 15 as the resin. I was thinking you meant to treat the metal prior to traditional fiberglass application. I thin I will go this route.
yes, you can buy a kit that has the POR 15 and the mesh backing made by POR 15. But the mesh they sell is kinda crappy and it is pricey to. So you use the fiberglas matting instead of the POR 15 mesh. And it works a whole lot better. Paint the POR 15 on the surface, it paints thick. Then place the fiberglas matting over the POR 15. Then put POR 15 over the matting and The POR 15 is self leveling and will dry rock hard, great stuff.
I think I would be looking for someone parting out a 66 and cut a patch for it.
~Jim
yeah, metal metal metal...you will be happy you did
My Project Bolt
