1 members (Forty9),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 48 | POR 15 and fiberglass mat would be a perfect solution for that.
1950 3804 Pickup
| | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 |
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
| | | | | Joined: Dec 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 48 | Yes it does. You can use POR 15 and fiberglass mat and it is better than resin because you can put it over rust and it will stick and stop the rust as well as fill the hole. I agree that fiberglass resin and mat suck, but we aren't talking about that.
1950 3804 Pickup
| | | | | Joined: Jan 2011 Posts: 35 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 35 | This is off-topic but I like the train picture #16. Is there a story behind that?
Thanks, Steve | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | man am i glad I live down south-never seen rust like that down here.
smaiocco-i have that same pic on my PC, IIRC it's somewhere in North Cali, back in the 60s. | | | | | Joined: Jan 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 126 | I got that picture from the HAMB board, I don't know anything about it except that its in CA, I like to think my truck could be on there, she's a California girl.... | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | Yes it does. You can use POR 15 and fiberglass mat and it is better than resin because you can put it over rust and it will stick and stop the rust as well as fill the hole. I agree that fiberglass resin and mat suck, but we aren't talking about that. i done mine that way, works great. That POR 15 is pricey but it does do the job. | | | | | Joined: Jan 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 126 | OK, now I'm tracking. You guys mean to use teh POR 15 as the resin. I was thinking you meant to treat the metal prior to traditional fiberglass application. I thin I will go this route. | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | yes, you can buy a kit that has the POR 15 and the mesh backing made by POR 15. But the mesh they sell is kinda crappy and it is pricey to. So you use the fiberglas matting instead of the POR 15 mesh. And it works a whole lot better. Paint the POR 15 on the surface, it paints thick. Then place the fiberglas matting over the POR 15. Then put POR 15 over the matting and The POR 15 is self leveling and will dry rock hard, great stuff. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I think I would be looking for someone parting out a 66 and cut a patch for it.
~Jim
| | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | yeah, metal metal metal...you will be happy you did
