| | | Forums66 Topics128,090 Posts1,056,018 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 15 New Guy | | New Guy Joined: Jan 2011 Posts: 15 |
Michael Salsa
| | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | Welcome to the bolt. Very nice ride. Just how much restoration did you have to do?... Looks factory fresh. | | | | | Joined: Jan 2011 Posts: 15 New Guy | | New Guy Joined: Jan 2011 Posts: 15 | barn find,seems to stay at around 180 temp has flex fan,I think should get electric fans on it what ya think
Michael Salsa
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tintoptexan, welcome to the stovebolt. You have finally arrived at home  Lots of Texans around so you'll be hearing from some of the Texas connection before long!! Thats a sweet ride. I worked at Chevy dealer in 65/66 and those pickups are roomy, look nice and will go if you want it to. Lucky you that you have some of the options...PB/PS. Thanks for the pics. | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | New to Stovebolt and new to auto restoration. I just purchased a 48 1/2 ton Chevy Pickup that had been modified with the frame/bed shortened. All wheels are 12 lugs and the 216 has been replaced w/a 235. Appears someone cut the frame about where the bench seat would start, and attached the rear end/rear frame from a 1 ton or so. Has double rear springs with a huge rear end and a 4 speed column trans, with a granny gear that could pull out tree stumps. I don't want the heavy stuff, looking to do a frame off and will post pics when I figure how to do it. Wonder if anyone knows of a club/group of old chevy guys in the Conroe/Woodlands,N. Houston,Tx area?
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Welcome to the Stovebolt,Allen. Lots of great folks here and even more knowledge. Sounds like you have quite a project ahead of you. I'm sure you'll find lots of Texans here and lots of good idea's.
Just FYI....a moderator will probably move your post so that it will a topic of its on...AND to find answers to your questions always try to post them in the most appropiate forum for the most reviews and comments/idea's.
Good luck, see ya around the shop. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome Joe & Dana, nice looking truck, also nice to have the 283. Sounds like you intend to keep her indoors from now on, don't blame you.
Leo | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | There guys up here with rolling frames for 200 or so, if I wrw you if buy a project truck for under 1000. Swap cabs take the best parts of the two and recompile you money parti g out what cha don't need. Up in Denver I can buy a truck for 600/1000. If you had to drop a grand on a project you could steal the frame and whatever else you needed ,then sell the rear slowly as ppl need ( someone is alway looking for this stuff, and the parts are common which means that although they r not rare they are in demand cause folks build them,and someone will need that's stuff ) | | |
