0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | Where should I locate the battery on my '51 3100, below passenger floor or on the firewall? This will be a driver ,not a show truck. Thanks | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Isn't there already a box for it under the floor? If so, why would you go through the trouble of mounting something on the firewall?
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I put mine behind the back seat, after one winter here in Pa. the battery took a beating from the road salt! Needless to say we relocated the gas tank to under the bed to create space. The radio is behind the seat also, made a box for it. The hole for the radio on the dash was welded up by the previous owner! | | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | Isn't there already a box for it under the floor? If so, why would you go through the trouble of mounting something on the firewall? Yes there is a box attached to the frame on the passenger side ,as original,but when I bought the truck ,it had a tray welded to the firewall which I took off for painting ,etc. I thought it would make a cleaner looking job to put it back under the truck if there were no issues with that. The truck will never be driven in the winter so salt is not an issue. Thanks | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | If you are looking for a bigger or drop-down box these guys sell lots of options. http://www.speedwaymotors.com/Bolt-In-Battery-Box,5334.html | | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | Any other opinions as to where the battery should go????? Thanks | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Yes another suggestion
From experience batteries that are out of sight are out of mind. They do not get the care they need.
Make it obvious and easy to reach. In theory you will check water level etc - like I did NOT.
Dan Bentler | | |
