2 members (55shaker, Steelonsteel), 117 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
#715369 01/26/2011 4:22 PM
1 Offline
Where should I locate the battery on my '51 3100, below passenger floor or on the firewall? This will be a driver ,not a show truck. Thanks
Isn't there already a box for it under the floor? If so, why would you go through the trouble of mounting something on the firewall?
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
I put mine behind the back seat, after one winter here in Pa. the battery took a beating from the road salt! Needless to say we relocated the gas tank to under the bed to create space. The radio is behind the seat also, made a box for it. The hole for the radio on the dash was welded up by the previous owner!
1 Offline
Yes there is a box attached to the frame on the passenger side ,as original,but when I bought the truck ,it had a tray welded to the firewall which I took off for painting ,etc. I thought it would make a cleaner looking job to put it back under the truck if there were no issues with that. The truck will never be driven in the winter so salt is not an issue. Thanks
If you are looking for a bigger or drop-down box these guys sell lots of options.
http://www.speedwaymotors.com/Bolt-In-Battery-Box,5334.html
1 Offline
Any other opinions as to where the battery should go????? Thanks
Yes another suggestion
From experience batteries that are out of sight are out of mind. They do not get the care they need.
Make it obvious and easy to reach. In theory you will check water level etc - like I did NOT.
Dan Bentler
