| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | What works best for a wide pulley on a 10SI alternator in an AD, 216 with original 5/8" belt? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bowtiefan, I have installed a generator pulley on an alternator in the past, they both have the same bore 17mm I believe. If I remember correctly I had to make a shim to keep the fan from rubbing on the alternator housing, hope that helps. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'll add that I've installed alternator pulleys on generators.
You should be able to figure something out. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can use a gen pulley. Speedway motors does have a custom pulley for that. It is a little cleaner install. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Thanks for the help. I was told I could not use the generator pulley, but I just went back out to try it (which I should have done in the first place) with a shim and it seems to be OK. Very little shaft left for lock washer and the nut, but I expect I can use Locktite on the nut! I ran it for a little bit in the garage and no probs! Now I will research on how to wire it! | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Alternator up and running. Did not like the pulley set-up from the generator. Not many threads holding the nut on. Found a replacement online, works much better. Also the cooling fan is incorporated with the stock pulley and is too small for the alt. Purchased a new fan with the pulley. Modified the original generator brackets to use on the alternator. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | FYI, if you put the lock washer behind the pulley instead of the nut, the fan spacing if fine and there will be enough threads for the nut. With a dab of Lock-tite and all is well.
See the USA in your vintage Chevrolet! My Blog | | |
