4 members (wilbur53, walter74, 2 invisible), 94 guests, and 0 robots.
Topics128,076
Posts1,055,920
Members48,429
#714977 01/25/2011 1:33 PM
What works best for a wide pulley on a 10SI alternator in an AD, 216 with original 5/8" belt?
3B Offline
Hy bowtiefan, I have installed a generator pulley on an alternator in the past, they both have the same bore 17mm I believe. If I remember correctly I had to make a shim to keep the fan from rubbing on the alternator housing, hope that helps.
I'll add that I've installed alternator pulleys on generators.
You should be able to figure something out.
Riding in the Passing Lane
You can use a gen pulley. Speedway motors does have a custom pulley for that. It is a little cleaner install.
1972 Chevy c10 Cheyenne Super
Thanks for the help. I was told I could not use the generator pulley, but I just went back out to try it (which I should have done in the first place) with a shim and it seems to be OK. Very little shaft left for lock washer and the nut, but I expect I can use Locktite on the nut! I ran it for a little bit in the garage and no probs! Now I will research on how to wire it!
Alternator up and running. Did not like the pulley set-up from the generator. Not many threads holding the nut on. Found a replacement online, works much better. Also the cooling fan is incorporated with the stock pulley and is too small for the alt. Purchased a new fan with the pulley. Modified the original generator brackets to use on the alternator.
FYI, if you put the lock washer behind the pulley instead of the nut, the fan spacing if fine and there will be enough threads for the nut. With a dab of Lock-tite and all is well.
My Blog
