3 members (TUTS 59, Jon G, 1 invisible), 163 guests, and 0 robots.
Topics128,157
Posts1,056,874
Members48,456
I think I'll mount a hood light with a mercury switch. Has anyone done this? I suppose any switch would work.
~Jim
I installed one from a wrecking yard, GM pickup. The switch was built in the fixture. Just run power to it and mount.
45 Chev 1/2-ton (what's left)
I've installed those. Just be sure that the bracket the holds the light is installed at the correct angle so the light doesn't stay on when you close the hood. It may required a little fine tuning, but isn't difficult.
Doesn't the vibration or bumps, and g-forces from driving make the light go on and off ?
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
You will have to hide under the hood while your buddy drives to see. Sorta like the refrigerator light dang
Well really, you can just hook up the light outside the hood and see when it goes on.
andy46 -No, the vibrations, bumps, etc do not make the light come on unless the hood opens.
Don't laugh, I've done that.
~Jim
You have done what
Hide under hood while buddy drives - awful trusting soul - I would be looking for big and deep mud puddle. Not sure if I would do it but I will confess to thinking about it.
Dan Bentler
have done what
Dan Bentler
I was 17 at the time and like all 17 year old's, an idiot. The exhaust manifold got pretty hot!
~Jim
Have used several, a little adjusting and they work well.
Don't leave the door open in the photo dark room. All the dark will leak out!
1954 Chevy Half-Ton
More pix on Shutterfly
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
