6 members (46 Texaco, Scott, 3B, Robert Crandall, KEVINSKI, 1 invisible), 83 guests, and 4 robots.
Topics128,185
Posts1,057,275
Members48,467
My 216 on my 49 Fleetline suddenly will only run at higher rpm and just dies at idle.(Choke must be on also)
I think I have done it all.
Changed carb,points, plugs, wires, coil, fuel pump, gas is good, head gasket changed last year. Valves not sticking. Plugged vacuum from manifold to wipermotor (no change).
Only thing I have noticed is that it is easy to turn over by hand (springs weak?)
Will this cause this?
Gonna check the vacuum at plugs and manifold but cant think of anything else. Any help is appreciated. I work on these 216's all the time but this has me stumped.
Eric
If it's easy to turn by hand with the plugs in, I'd guess compression problems. Weak springs should be okay with low rpm's and worse as it speeds up (valve float), unless they are so weak the valves don't close at all.
Im thinking the springs are weak, so the valves are not closing completely. I just dont know.
I didn't see where you adjusted the valves. That would be my first place to look.
However, the not running at idle really sounds like a leaking intake/exhaust manifold gasket. It is not uncommon for the head or the intake and exhaust to warp, causing this problem.
I vote with bbsd.
A quick, dirty, and just a little dangerous diagnostic technique is to look for manifold leaks: with the engine running at the lowest idle you can manage, open (just a little) an unlit propane torch and direct the torch-end around the intake and exhaust gaskets (and maybe the carburetor lower-body). If the idle speed picks up, you have a vacuum leak due to a bad gasket/fitting/etc.
Ya I checked the gaskets but they are sealed and new when I did the head last year. I readjusted the valves also but gonna go thru them again. Any other things I can check?
Compression check?
set the idle up
Redryder pix
My Hotrod
Did the idle but compression b next.
Riding in the Passing Lane
It sounds like a carb problem but you said you tried another carb. Have you set the idle speed up like Cletis says. Try turning the idle jet richer. Put your hand or a rag over part of the carb neck & see if the speed picks up. If so you hbave a vacuum leak or plugged idle passages.
What part of Ks. are you in?
1972 Chevy c10 Cheyenne Super
Cletis an't here George...lol
Redryder pix
My Hotrod
Yes I had the exact problem with the other carb. They are both new rebuilts. Just havent had time for the compression check yet. I am gonna get new springs and seals on the way though (cant hurt). Im in Gardner KS, freezin!
Don't laugh. I'm an old man. I just know you 2 come from the Lone Star state.
Edub, do you have the old carb or did you turn it in?
No I keep em all original, carb. was fine and put it on another car.
Y
yar Offline
Y Offline
edub10068, I have had this happen to the carter W1 on my '36 Chevy pickup occasionally over the years. In each case a tiny obsruction found its way into the idle circuit. The solution that worked for me every time was to remove the idle air screw, squirt in a little carb cleaner and then blow compressed air through it.
That also worked on the Solex carb I had on a VW Bug decades ago.
Ray
