6 members (MickeyP, 5 Window 9434, cmayna, 78buckshot, Samantha, 1 invisible), 94 guests, and 2 robots.
Topics128,062
Posts1,055,851
Members48,428
#714835 01/25/2011 12:46 AM
can you replace just the bent push rods or do you have to replace all of them. Also
how about the hydraulic lifters can you replace one or two or do you have to do them all?
Ex Hall Monitor
Ex Hall Monitor
If you get the stuck valves freed up you can most likely spend a few minutes with a hammer & straighten the push rods to the point you won't need to buy any. The key is unsticking the valves. I've never dealt with hydraulic in a 235 but if they're like any others I've messed with you only need to replace the bad ones.
Tiny #714858 01/25/2011 1:38 AM
The tricky part will be finding individual new lifters to replace the bad ones with. Most parts places want to sell complete sets. There are usually several sets on Ebay at any particular time.
you can get individual lifters from chevs of the 40's, but I would replace them all, if one is worn, its a pretty good bet they all are.
And Tiny is correct you can just straighten the pushrods provided they aren't really bent over so much to change their length.
Or you can change those only one at a time if necessary, but don't bother if you don't get the valves loosened up, it will just do it again.
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
