0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | Installing new stock (turn signals added) wiring on 1956 3200. Got the harness from M&H. I am putting New LED tail lights that have two wires (black & white). On Led assemblies does it make a difference which wire goes where. What I don't know is how they are wire internally. Are they different from the old two contact bulb system. I have some concerns with the M&H harness but will report later when installed. I assumed the Black wire to the right rear was my tail light line and I tapped into it for my center License plate bulb (no provision for this light in harness). | | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | First - obviously - check the instructions. It's my understanding that with LED's, polarity does matter. On mine, the BLACK is taillights, red is brake lights and white is ground. Go figure.
If yours is only 2 wire, I'm guessing it's internally grounded/grounded by the housing. I'd do a quick bench test to be sure.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I've also just finished hooking up my LED Lights,and discovered the ground was white. Black was tail and red was brake, the same as The Green Farmers. The lamps came with NO instructions/diagrams I checked mine by hooking them up to a battery with no ill effects. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
