3 members (Hotrod Lincoln, Wally / Montana, Southerntruck), 72 guests, and 2 robots.
Topics128,060
Posts1,055,831
#710693 01/10/2011 10:41 PM
i have a 250 with a 3peed jsaw installed n my 47 fleetline n my cloum a have truck gear box when n installed the rods the gear are to close to shift and when i just my clutch all the way it still grandes when i try to shift into 1st gear am using the same set up from my fleetline what should i do next thanks
harborarea #711524 01/13/2011 4:50 PM
3B Offline
Hy harborarea, your post is difficult to follow, are you saying that you have installed a much newer engine and transmission in your truck? And you can't make the shift linkage from the old transmission work with the new transmission? The shifter arms on the new transmission are probably totally different in shape and design from the old transmission, you may have to make extensive modifications to the linkage to make it work. The clutch linkage may also need modification in order for it to make the clutch work properly.
3B #711559 01/13/2011 7:28 PM
You will likely recieve more help if you use punctuation and form sentences. Spell check would not hurt either.
darn.
I think I spit a bit of beer on the keyboard.
harborarea #711730 01/14/2011 7:34 AM
H Online: Content
Text-message grammar and spelling just doesn't work on us oldtimers. We grew up making complete sentences, and using commas, periods, and question marks!
I'm with Hotrod 100% on this one.
crenwelge #711899 01/14/2011 10:02 PM
If I may add to this, when you come on a website seeking technical information it ought to be obvious you are not dealing with the text crazed generation. If you can't take the time to at least try to ask an intelligible question I won't take the time to try to decipher your text speak. Spelling mistakes I can overlook but not run-together sentences with no attempt at punctuation.
Cletis #714636 01/24/2011 5:11 AM
sorry for my spelling got everything runing good now i have a problem now when i hit the brake padle it hit the tranny linkage
harborarea #714651 01/24/2011 6:43 AM
Is there a question here?
We need a little bit more of a description of the problem if we are to offer you any help. If English isn't your first language we can be a little patient. Just let us know.
Perhaps the shifter arms are on the transmission backwards?
