| | | Forums66 Topics128,051 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 7 New Guy | | New Guy Joined: Apr 2010 Posts: 7 | i have a 250 with a 3peed jsaw installed n my 47 fleetline n my cloum a have truck gear box when n installed the rods the gear are to close to shift and when i just my clutch all the way it still grandes when i try to shift into 1st gear am using the same set up from my fleetline what should i do next thanks
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy harborarea, your post is difficult to follow, are you saying that you have installed a much newer engine and transmission in your truck? And you can't make the shift linkage from the old transmission work with the new transmission? The shifter arms on the new transmission are probably totally different in shape and design from the old transmission, you may have to make extensive modifications to the linkage to make it work. The clutch linkage may also need modification in order for it to make the clutch work properly.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | .,?!
You will likely recieve more help if you use punctuation and form sentences. Spell check would not hurt either.
John | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | .,?!
John darn. I think I spit a bit of beer on the keyboard. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Text-message grammar and spelling just doesn't work on us oldtimers. We grew up making complete sentences, and using commas, periods, and question marks! Jerry
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I'm with Hotrod 100% on this one. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If I may add to this, when you come on a website seeking technical information it ought to be obvious you are not dealing with the text crazed generation. If you can't take the time to at least try to ask an intelligible question I won't take the time to try to decipher your text speak. Spelling mistakes I can overlook but not run-together sentences with no attempt at punctuation. | | | | | Joined: Apr 2010 Posts: 7 New Guy | | New Guy Joined: Apr 2010 Posts: 7 | sorry for my spelling got everything runing good now i have a problem now when i hit the brake padle it hit the tranny linkage | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | ???
Is there a question here?
We need a little bit more of a description of the problem if we are to offer you any help. If English isn't your first language we can be a little patient. Just let us know.
Perhaps the shifter arms are on the transmission backwards? | | |
