0 members (), 70 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
Need direction to where I can look up the casting /id numbers on a group of chev and gmc 6 manifolds.Do'nt know what they go to and then to what I can match thenm to.ALSO have a GMC 248 with no head.BUT I've got a head with casting #g2 2 2136477 bb will that work on the 248? Thanks folks
The head you have is for the pop up pistons that were used from 39 through 52. If your engine has flat pistons, it the wrong head.
Thank you sir.So if the 248 does have pop up pistons it will be useable? I'm going to lean on you a bit more and ask -Do you know of a chart -reference point to look up info on manifolds and transmissions --all gmc and chevy straight 6 items?Sid Stephenson-over in the Woodlands
