| | | Forums66 Topics128,180 Posts1,057,150 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 27 | Need direction to where I can look up the casting /id numbers on a group of chev and gmc 6 manifolds.Do'nt know what they go to and then to what I can match thenm to.ALSO have a GMC 248 with no head.BUT I've got a head with casting #g2 2 2136477 bb will that work on the 248? Thanks folks | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | The head you have is for the pop up pistons that were used from 39 through 52. If your engine has flat pistons, it the wrong head. | | | | | Joined: Jul 2009 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 27 | Thank you sir.So if the 248 does have pop up pistons it will be useable? I'm going to lean on you a bit more and ask -Do you know of a chart -reference point to look up info on manifolds and transmissions --all gmc and chevy straight 6 items?Sid Stephenson-over in the Woodlands | | |
