5 members (DadsFirstPickup, homer52, Otto Skorzeny, dt235sd, 2-Ton), 71 guests, and 3 robots.
Topics128,049
Posts1,055,661
#714255 01/22/2011 11:24 PM
OK...I tore out all the old wiring from a perfectly good running truck and replaced with new. As stated above, everything ran fine. The old wiring just needed to go.
Anyway, I re-wired the motor group and ignition per directions verbatim from a wire-harness manufacturer. My motor turns over just fine, but I'm not getting any spark from the plugs nor from the top of the coil when I pull that top wire off that leads to the distributor.
Any ideas? I have a straight 6, 235 all original stuff.
Thanks!
Thom Masterson
Check your ignition switch to see that you are getting power to the coil in ing.position and in start position.
1937 Chevy 1/2-Ton
