1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 19 New Guy | | New Guy Joined: Oct 2006 Posts: 19 | 54'1 ton 17" 2pc wheels.
Are there any later 8 lug wheels that will fit???
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | yes, Singles or duals? What are your reasons for wanting to swap wheels? | | | | | Joined: Oct 2006 Posts: 19 New Guy | | New Guy Joined: Oct 2006 Posts: 19 | Single wheels. The 2pc joints are rusty and pitted,my tire guy won't mount new tires on them even if they are blasted. Also, I could put on some tubeless tires. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Try searching this section, we've covered wheel choices more times than I can count..
I usually recommend 19.5" wheels, because I think they look nice, tall and skinny, and they always fit over the rear brake drums, not all of the smaller choices will. However they are a little difficult to find, but not impossible.
Grigg | | | | | Joined: Aug 2005 Posts: 12 New Guy | | New Guy Joined: Aug 2005 Posts: 12 | Here is another option: Go to http://www.pacerwheels.com Select RWD and you will see the wheel that is on my truck. Click on it and it will give the detail below and more. Pacer part number is 161M-6781 Wheel size is 16X7 Bolt circle is 8X6.5 Backspacing is 3.62 inches I hope this helps, Gater | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Step vans were big users of 19.5 wheels. If you see an old step van being used for storage, look at the wheels. | | | | | Joined: Oct 2006 Posts: 19 New Guy | | New Guy Joined: Oct 2006 Posts: 19 | I am going to go with my wheel centers and have new rims welded on. That way I can use stock hubcaps. thanks | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You can find 19.5" wheels with hub cap clips, or install some... | | | | | Joined: Dec 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 48 | I took my wheels to a truck tire place to get tires mounted and they didn't care that they were 3 piece rims. Nobody else in Charlottesville will touch them, but the 18-wheeler tire guys could care less.
1950 3804 Pickup
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | I've seen quite a few posts referencing the 19.5" wheels from a step van. What years of stepvans should one be looking for? All GM I assume? Anything to stay away from? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | From about 56 into the 90's, but not all will have 19.5" GM mostly, but wouldn't rule out ford and dodge either.
I know that's pretty general and covers a lot, but I haven't seen any rules or givens on where you absolutely will find them, all you can do is look.
None to stay away from that I know of, so long as they fit your truck.
Grigg | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Ford and Dodge use the same bolt pattern. Most if not all of them have a little bigger hole in the center which makes no difference. They are stud piloted anyway. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Ford and Dodge use the same bolt pattern. Most if not all of them have a little bigger hole in the center which makes no difference. They are stud piloted anyway. Stud piloted for single wheels, so no problems there. Hub piloted for duals, and center hole size matters in that case. Grigg | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think Chnaus's first response was that he had single wheels, but I'm not sure where we are at now. If he want's duals, he needs to look for hubs and wheels or custom wheels. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | 54'1 ton 17" 2pc wheels.
Are there any later 8 lug wheels that will fit??? to bad that you are to far away I have a set of 4 17" split and a set of 6 18" budd 8 stud from my 65 1t. also have a set of 4 15 8stud split ron | | |
