4 members (Otto Skorzeny, MNSmith, jfjbjr, joe apple), 261 guests, and 2 robots.
Topics128,080
Posts1,056,062
Members48,433
#714045 01/22/2011 2:23 AM
Hi Bolters...need some expert advice. I have a grandson with a 1954 3600 ad. He is a minonite and cannot have a computer. He has trouble with vac. advance and timing. He has a 1973 250 chev. six, 4.1 liter, Rochester single bbl. In it. He says vac. coming from base is too strong and messes up timing. Is this possible?. He put a tiny ball valve in line to reduce vac. in order to run at all decent, I said I would ask the experts. What is the proper way to set timing so it performs thruout the rpm curve..Appreciate input Sepp
Plattelnjpichler
sepp22 #714047 01/22/2011 2:30 AM
Tell him to get a horse! smile
Actually, most carburetors have two types of vacuum ports- - - - -Manifold vacuum, which is taken from beneath the throttle plate, and "ported" vacuum which is not present at idle, and comes in gradually as the engine speed increases. If he's putting full manifold vacuum to the advance at idle, that's probably the source of his problem. Try to find a carb port that does not get any vacuum until the engine speeds up above idle RPM.
Jerry...thank you very much. Makes sense. I wil ask to see where he is picking up Vac. Much appreciated...Sepp.
Plattelnjpichler
sepp22 #715111 01/25/2011 9:46 PM
Riding in the Passing Lane
The ball restricter is a bad idea. The vacuum needs to fall off imediatly when you accel. hard. Jerrys sugestion is good. Also he may have too much initial timing.
1972 Chevy c10 Cheyenne Super
Thanks again. I remember timing my own 53 3100. I always block off vac. hose to time at idle. I have to see for myself when I get out to their farm. 150 mi away. Going there when weather gets better here in Pa. Appreciated....Sepp
Plattelnjpichler
sepp22 #715727 01/27/2011 5:18 PM
My vac line has a fitting that where it hooks to the vac line the hole is 2x the size of the hole that screws into the carb.(small hole is about 1/8 across vs 2/8 on opposite side.
1937 Chevy 1/2-Ton
