7 members (Hotrod Lincoln, klhansen, Steelonsteel, Ribside, asilverblazer, greenie-reddy, 1 invisible),
63
Mod | | | Forums66 Topics128,261 Posts1,058,326 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | I'am getting ready to install a new windshield and gasket. The gasket I have picked up is made by "Precision". And part of the gasket is wider then the other part. Does anyone know how the gasket fits around the windshield? Does the wider part go around at the top of the windshield ot the bottom? thanks for any help.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there's a 'flap' that goes to the inside top so the ends come down the sides and are captured by the metal trim strip below the glass over the defrost vents .... if that's clear  Bill | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | Thanks Bill for the help on the seal. So the flap's ends come around the ends of the windshield and go about a inch or so around the bottom curve of the glass? thanks agian for the help | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you got it - try to get it on the glass pretty even right off cuz there's no moving it once in place!
Bill | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | Got er done, Thanks Bill for the help on the seal. | | |
