4 members (1955 1 Series, Maybellene, kbenz, cmayna), 80 guests, and 1 robot.
Topics128,157
Posts1,056,872
Members48,456
Z
Junior Member
Junior Member
Z Offline
How can I find the factory pinion gear depth setting. I have a 1964 Chevy C-10, 3/4 ton, 12 bolt, 18 spline axel rearend. I would like to know the fatory depth setting so I can calculate what shims to start out with to setup the pinion depth for a new carrier, ring, and pinion. The original pinon does not have a depth marked on it. The new pinion has a depth of 2.753 markes on it. Any one got any ideas on how to find the original depth or what shim pack to start with.
Riding in the Passing Lane
You could measure it before you tear it down but it,s pretty much trial & error.
1972 Chevy c10 Cheyenne Super
zepaman,
Do you have the original gears and shims ? If so this is where you have to start.Install the same shim pack under the pinion bearing.If you want to make thing easier buy an extra pinion bearing and hone it out .Other wise you have to press the bearing back off if you reshim.If you have no experience in setting it up I would suggest finding some one.It's an art and takes some time and patience .Good Luck
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
Junior Member
Junior Member
Use the pinion depth that is marked on your new ring and pinion set.That is what the manufacture of the new gears has determined is the correct depth for your pinion to be installed at so that it will mesh properly with your new ring gear. Like 61 Suburban said find someone with prior experience to help you with this.
BAN LOW PERFORMANCE DRIVERS...
NOT HIGH PERFORMANCE CARS !!
Z
Junior Member
Junior Member
Z Offline
Thanks for the suggestion. I found a Chevy mechanic that will do it on the side. He also told me to get an extra set of pinion bearings so he could hone one set out to use for setting up the shims. Thanks for your advice.
