2 members (78buckshot, 1955 1 Series), 114 guests, and 2 robots.
Topics128,062
Posts1,055,857
Members48,428
#713643 01/20/2011 11:03 PM
Putting a 73 400 small block, and 700r4 trans in my 59 gmc. The external balance flexplate I have has 139 teeth. I am trying to figure out what application to look for a starter. The 73 chevys with a 400 have 168 tooth flexplates. I know 6.2 deisels used a 139 tooth flexplate--but starter wont fit a small block. Anybody have any ideas on what starter will work?
1950 3100 3 windo
1951 gmc 102
1958 chevy 3200
1959 gmc 102
1963 c20
1959 buick lesabre
1961 buick lesabre
i have a couple of six volt starters here at the shop. your welcome to come check them out, that is if your anxious to get out of the city eeeek
Y
Y Offline
I don't have the answer, but will throw this out there. Does your engine use the starter with diagonal or parallel bolt holes in the block? I had a 250 with 153 tooth flywheel and in order to use the 168 tooth flywheel I used the starter off a 350.
