| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 30 New Guy | | New Guy Joined: Jun 2007 Posts: 30 | Putting a 73 400 small block, and 700r4 trans in my 59 gmc. The external balance flexplate I have has 139 teeth. I am trying to figure out what application to look for a starter. The 73 chevys with a 400 have 168 tooth flexplates. I know 6.2 deisels used a 139 tooth flexplate--but starter wont fit a small block. Anybody have any ideas on what starter will work? 1950 3100 3 windo 1951 gmc 102 1958 chevy 3200 1959 gmc 102 1963 c20 1959 buick lesabre 1961 buick lesabre
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i have a couple of six volt starters here at the shop. your welcome to come check them out, that is if your anxious to get out of the city  | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I don't have the answer, but will throw this out there. Does your engine use the starter with diagonal or parallel bolt holes in the block? I had a 250 with 153 tooth flywheel and in order to use the 168 tooth flywheel I used the starter off a 350. | | |
