7 members (Gdads51, Phak1, Gray_Ghost, Leo, Oswald, Otto Skorzeny, 1 invisible), 133 guests, and 1 robot.
Topics128,137
Posts1,056,430
Members48,441
#713402 01/20/2011 1:48 AM
OK, so they don't exist. Apparently the umbrella type oil deflectors didn't appear until the 1941 head design. Has anybody used a modification to stop one of these from burning oil that leaks through the valve guides. I have seen a posting on another site that the deflectors from a Ford 302 work out fine. I don't really understand how they would fit on.
1951 1 Ton Completed
It is common to use umbrella seals on those early heads. They fit around the valve stem and hang down over the guide.
Here is a ebay LINK to some as an example.
My Blog
Dave,
thanks, now I understand. They are real seals that sit on the guide.
they cost like 68 cents apiece at napa
Would they keep the valve stems too dry?
The umbrella type seal is a snug fit on the valve stem and moves up and down with the valve; they don't attach to the guide, just "umbrella" the oil away from the guide bore. I don't use the seals on the exhaust valves; I figure they need lubrication and they don't suck the oil by like the intakes do. If the exhaust guide bore and valve stem are a good fit, little oil will pass.
Thanks, I think I got it now.
Most modern engines use what are called PC seals on the intake and exhaust. They fit tight on the valve and the guide preventing almost any oil from getting to the guide.
Example
You would think valve guides would need oiling but they seen to work fine with almost nothing.
The advantage in PC seals are, they stop what amounts to a vacuum leak past the guides on the intakes, and prevent exhaust gasses from getting past the guides on the exhaust, and entering the engine.
My Blog
