5 members (55shaker, 52Carl, fonz8261, 78buckshot, RoadsScholar), 98 guests, and 4 robots.
Topics128,100
Posts1,056,515
Members48,448
anyone know where you can buy a new repro cloth covered harness like original? i have found them, but its 750bux! is that what they are really going for? jeeeze!
....I can't name one right this minute but DEFINITELY shop around. Hang tight. Surely someone here knows where to go.
YnZ
Rhode Island
They are very expensive
Good Luck
I need one too !
have just started looking..
12V with alt.
1951 chevy 3100 short bed frame off resto.
The two DADS50 suggested are the only two cloth covered harness makers that I know about also. I looked for several months before buying mine.
There are a lot of other good harness makers that work with modern wire. Many have been discussed on this forum.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
How about YNZ's yesterdays parts, and chevs of the 40's are 2 more I saw on a google search. Both have cloth covered originals. I also see Jim Carter has one for $500...
Now we just have to sort out quality!
YNZ was mentioned by DADs50 and I'm not sure who makes the harnesses for JC and Chevy of the 40's.
-Unknown-
Foster,
I used Rhode Island for my '51. It wasn't cheap, but they were very good about what I wanted. My truck didn't have turn signals and they incorporated it into the harness. All color codes were correct. Very easy to install. There is a lady there who really knows her stuff. I can't remember her name, but when you call they will pass you on to her. She was great. I also had my harness modified for fog lights. She will ask you exactly what you want and they will build any extras to the harness. If you use them, you may want to have them add about 2-3 inches to the tail light/brake light portion. Mine seemed a little short, but it could be the way I installed it. The negative wire from the coil to the dizzy was missing from the original shipment and when called they were happy to help. This is kinda long, but I thought it may be of some assistance to you and others. Rhode Island did a great job for me.
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
do you have a contact # and info for them. how much did your harness cost you? ive been looking around and im fine with expensive as long as the quality is there. thanks for the update
Originally Posted by DADS50
click link above for Rhode Island Wiring home page. Phone number and catalog
51bolt do you have any pic's?
DADS50,
I will work on getting some pix up.
Mark
1951 Chevy 3100
