2 members (Buckeye998, TUTS 59), 338 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
How many teeth on a 1950 Chevrolet starter, 9 or 11?
Bruce
My Trucks
Stuff I Collect
I guess this is not to quickie a question. From what I've been able to determine, in the '30s and early '40s they had a 9 tooth starter but what about 1950???
Bruce
My Trucks
Stuff I Collect
Y
Y Offline
I'm trying to remember what little I know about the starters. I just counted the teeth on 3 starters I have, knowing they came off my 216's that were in my 51 & 53. I come up with 9 teeth. The only difference I can recall is regarding 6 volt vs 12 volt changes to the flywheel. 139 teeth vs 168. The size of the starter drive shaft and gear changed also. I would assume the 30 & 40 startes had 9 teeth. If I can document it I will let you know.
Thanks. I'm trying to help out a friend who is fixing up a '50.
Bruce
My Trucks
Stuff I Collect
I've got a 40 car starter still bolted up to the engine and transmission. If all else fails I can pull it and count. Looks like yakimabowtie has the answer for later engines.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
The Master Parts book seem to show that the same number of teeth were used on 6v trucks back to the 30s.
Hate to drag up an old thread, but that seems better than starting a new one about the same thing.
I know the difference between the 6v and 12v flywheel tooth counts, but what's the difference in the tooth count between the starters?
Truck is a '54, 235 with a solonoid starter. It's got a 139 tooth flywheel and the owner wants to go back to the foot start. I've found a starter with 9 teeth and just want to make sure it's compatible with the 139 toot flywheel.
Not a 100% sure, but I think the 12 volt starter drive has 9 teeth with the OD. of the teeth = 1 inch. 6 volt starter drive has 9 teeth also, but with an OD. of the teeth = 1 1/8 inch.
Brian
1955.2 3100 Truck
55 Shaker, I wish I could remember where I just read about this... But, sometime in the last week or so I thought I read the starter gears were different as well.
i.e. as mentioned in post #1
Give me ambiguity
or give me something else
I believe both 6 volt and 12 volt have 9 teeth but the diameter of the gear is different.
1951 1 Ton Completed
Thanks guys. If the gear diameter is different, I suppose I can just engage the bendix without the battery hooked up and see if the teeth mesh with the flywheel.
I ought to be able to see an 1/8" misalignment, even with my old eyes.
