| | | Forums66 Topics128,026 Posts1,055,406 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | How many teeth on a 1950 Chevrolet starter, 9 or 11?
Bruce | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I guess this is not to quickie a question. From what I've been able to determine, in the '30s and early '40s they had a 9 tooth starter but what about 1950???
Bruce | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I'm trying to remember what little I know about the starters. I just counted the teeth on 3 starters I have, knowing they came off my 216's that were in my 51 & 53. I come up with 9 teeth. The only difference I can recall is regarding 6 volt vs 12 volt changes to the flywheel. 139 teeth vs 168. The size of the starter drive shaft and gear changed also. I would assume the 30 & 40 startes had 9 teeth. If I can document it I will let you know. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Thanks. I'm trying to help out a friend who is fixing up a '50.
Bruce | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I've got a 40 car starter still bolted up to the engine and transmission. If all else fails I can pull it and count. Looks like yakimabowtie has the answer for later engines. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The Master Parts book seem to show that the same number of teeth were used on 6v trucks back to the 30s.
| | | | | Joined: Aug 2013 Posts: 34 New Guy | | New Guy Joined: Aug 2013 Posts: 34 | Hate to drag up an old thread, but that seems better than starting a new one about the same thing.
I know the difference between the 6v and 12v flywheel tooth counts, but what's the difference in the tooth count between the starters? Truck is a '54, 235 with a solonoid starter. It's got a 139 tooth flywheel and the owner wants to go back to the foot start. I've found a starter with 9 teeth and just want to make sure it's compatible with the 139 toot flywheel. | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Not a 100% sure, but I think the 12 volt starter drive has 9 teeth with the OD. of the teeth = 1 inch. 6 volt starter drive has 9 teeth also, but with an OD. of the teeth = 1 1/8 inch.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | 55 Shaker, I wish I could remember where I just read about this... But, sometime in the last week or so I thought I read the starter gears were different as well.
i.e. as mentioned in post #1
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I believe both 6 volt and 12 volt have 9 teeth but the diameter of the gear is different. | | | | | Joined: Aug 2013 Posts: 34 New Guy | | New Guy Joined: Aug 2013 Posts: 34 | Thanks guys. If the gear diameter is different, I suppose I can just engage the bendix without the battery hooked up and see if the teeth mesh with the flywheel. I ought to be able to see an 1/8" misalignment, even with my old eyes. | | |
