3 members (Phak1, Otto Skorzeny, moparguy), 122 guests, and 2 robots.
Topics128,129
Posts1,056,360
Members48,441
I've removed the windshield frame from my '41 pickup for replacement. In the process, I noticed there is a small hole in each side corner of where the windshield frame fits into the body. The hole connects to a short metal tube that runs through the top of the cowl, and then it appears this metal tube attaches to a rubber tube that drains to somewhere. In my case, the rubber tubes have broken off long ago. The principle seems to be similar to how the cowl vent drain tube works. But I'm wondering where these windshield drain tubes are supposed to exit. Can anybody tell me?
My toys:
'41 Chevy Model AL 3/4 Ton
'40 Chevy Model KD 3/4 Ton
Hinomoto 209N Tractor/Backhoe
Norwood LM2000 Sawmill
PJ 16' Trailer
and a Brand New Shop!
Be what you is, not what you ain't, 'cause when you is what you ain't, then you ain't what you is.
On mine there are steel tubes right in front of the door post (the one the hinges attach to). These extend from about 10” above the cab floor behind the side kick panels. They exit the cab and extend about ½” below the floor. They are right where the front of the rocker panel screws to the cab. I assumed that these were connected to the ones you described at the windshield frame with rubber hoses.
I had a ball in Missolua one time !!
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
When I did my truck, those tubes were long gone. I used clear PVC plastic tubing ( aquarium supply ), routed down and out thru floorboards. These end up concealed by kick panels. Other drain you might need to address is the one from the cowl vent area.
1940 Chevy KC 1/2-Ton
Thanks guys. Using the info you gave, I sure enough did find metal tubes hiding inside the door posts. It is obvious this is where the upper tubes connect.
Kip, come visit Missoula again sometime and I'll take you flyfishing. It's a great place to live.
My toys:
PJ 16' Trailer
Sorry for off topic, Missoula is a beautiful place, camped at the KOA there. Lots of non rusty old iron there.
Just make sure the metal tubes are not bent or clogged with dirt.
I took mine out as they were bent and took them to the local NAPA store and just got new metal tubing the same size along with the rubber to connect the windshield drain to the metal tubing running down the door posts.
What no one has mentioned yet is that those drain tubes were never designed to handle the amount of water that comes through/around the windshield seal . Even with the windshield tightly closed most of it ends up in your lap. cool
Has anybody successfully installed one of these crankout windshields that does not dump water in your lap when it rains and/or seal completely to keep the wind out when you do not want it open?
Last night I set my first windshield on my 41 1ton and still have some tweaking to do with it. After that one is complete I will start on my 46 Suburban.
It would appear that as a last resort I may have to glue/add foam rubber to the windshield opening on my body rather than the windshield frame.
Also what have you used to adhere the rubber seal to the windshield frame?
Thank you,
Dave Murray
Moderated by  ndkid275, Phak1
