0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Where can I find the specifications of the drive shaft parking brakes ? Since still ill I haven't had time to investigate, but the handle goes to bottom with no effect at all. So I'm in for a rebuild of park brake. My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Or adjustment. Check your service manual first, then have a look see at what you have under the truck.
Grigg | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I know it's a drive shaft e-brake. We have the same here in Sweden on the old Volvo Army 4wd vehicles.
I have no service manual. Will try to find it on the net...
Of course I will try adjusting if possible... =) My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | There are a few different types of drive line brakes that come on these trucks. The most common has a drum with an inner and outer shoe, then there is one with a band around the outside of the drum and still another has two shoes in the drum. All three of these brakes have different adjustment methods. The most common having the most complex adjustment start by ensuring that the brake is completely released and the wheel are chocked then loosen the jam nut on the bolt at the bottom that pushes up on the outer shoe. screw this bolt in to obtain a clearance between the shoe and drum directly above the bolt of .010" to .015" and tighten the jam nut. To the right side of the bolt that you just adjusted at the end of the bell crank that applies the force to the two shoes is a J bolt adjust the top nut on this J bolt up then the bottom nut up till you get a clearance between the inner shoe and the drum of .010 to .015 and tighten the top nut back down to hold this adjustment. The other two types are pretty straight forward and only have one adjusting point. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Thanks, I will surely save this for future use !!!
| | | | | Joined: Sep 2010 Posts: 19 New Guy | | New Guy Joined: Sep 2010 Posts: 19 | Here's a link to the '51 Truck Brakes Service Manual that I used to understand how the propeller shaft parking brake operates. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | That's exactly the brakes I have !! Thanks... My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
