1 members (1 invisible), 105 guests, and 3 robots.
Topics128,089
Posts1,056,440
Members48,443
I have to patch a couple areas on my 46 fram and was wondering what the correct thickness of the frame material is and whether its better to use sheet or angle iron for the patches.
Dean
The frame steel is .140" thick, I would use sheet, angle iron doesn't look even close, the web gets thicker and would never match the existing frame properly.
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
I need sections to fix the back of the frame including where the back spring bracket hangs. You have any from that area let me know how we can work it Thanks
Dean
You could also try the yellow pages for the nearest steal fab. shop near you, and get some channel iron (11/2x6x 11/2ins.)check out your frame, them you could slip it over the frame and make a lap joint instead of a but weld. Plenty of steal and plenty strong...Paul
Joe
I am still interested in the frame parts could you send me some photos or other information sounds lazy but I have limited experience with this type of rebuild but want to say I did it myself. My email is polaschdAembarqmail.com
Dean
