2 members (Alex52, Rich'sToys),
117
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71226 01/06/2007 5:11 AM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Been working on duplicating a front disk brake upgrade I saw on another web site and have reached the point that it looks like it will work. Disc Brake Upgrade Everything is straight forward except for locating the correct caliper bracket. I finally found a set that looked like the ones I saw on the other site today and hey presto, it all falls together. The bracket is from a 1991 Dodge B350 Maxivan, 2WD, gas powered, 9600lbs GVW. I looked at three different 1-ton Dodges in the boneyard today and only the high GVW one had the right parts. Here is the VIN from the donor vehicle: 2B7KB31ZXMK409516. The Dodge parts guy assured me he can find any part from the VIN number. It does look like I'll have to trim the stop adjusters from the steering arms. Next thing is to try rotating the adapter mounting holes upwards a bit to see if I can keep the adjusters.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#71228 01/06/2007 4:43 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Looks great. What disk/hub is that? I see from the pictures that you have the NAPA part numbers, but I'm curious what they fit.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#71229 01/06/2007 5:26 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Steve,
NapaOnline.com lists that rotor as being used in all 4 wheel positions but doesn't say what on.
I put in 1991 Dodge D350 1-ton pickup and it shows the 85604 rotor so that's one of the applications.
As my mockup sits right now, the rotor is not yet piloted to the hub. It looks easy to make up a ring to pilot the ID of the brake rotor to the hub but then I haven't talked to the machine shop yet.
The hubs are GMC/Chevy, '53 - '59, 3/4 & 1 ton w/duals.
#71230 01/07/2007 8:06 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Thanks John!
Please keep the details coming. It's likely some of us will be following you down this path in the future and we're all happy you're keeping good records!
#71231 01/24/2007 4:59 AM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Things are moving along on the front end rebuild and disk brake conversion. I called Benz Spring in Portland, OR ( www.benzspring.com) and ordered a set of front springs on Friday and the UPS guy dropped the springs and new u-bolts off today about 1:30. Shortly afterwards, the machine shop called and asked for an updated copy of my Autocad drawing for the caliper adapters. I sent it to him around 3:00 and picked up the finished brackets at 4:30. I've added a picture to the end of the album. The cold-rolled steel plates cost as much as the cutting on the water-jet did. Disk Brake Upgrade Over the weekend, I pulled the steering box for a rebuild, cleaned the area around the spring hangers and removed and replaced the bushings in the front frame hangers. I see today that the new springs come with the bushings already installed in them. I was VERY impressed with the service from Benz Spring. Called 'em on Friday and told them what I was working on, the guy says they'll go out Monday, and there here on Tuesday. Oh yeah, both the springs and the u-bolts are made in the USA!
#71232 01/24/2007 5:09 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 |
#71233 02/02/2007 12:50 AM | Joined: May 2006 Posts: 7 Junior Member | | Junior Member Joined: May 2006 Posts: 7 | Did I miss what year vehicle this is going on? i have a '46 3/4 ton that I would love to put disc brakes on. Just trying to figure out if a setup similar to this would work. I would definately like to keep the heavy suspension setup and improve braking capability. | | |
#71234 02/03/2007 1:04 AM | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Hey, me too. I have a 46 1 ton that could use better breaking. | | |
#71235 02/03/2007 2:18 AM | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Nice job. You have done a great job at making your caliper mounts I can only hope mine come out as good. I am looking at doing the same to my 56 6100 I think that I have found a rotor and caliper set that will work. They are 15” rotors and have the same 6 on 6” bolt pattern as my current drums. So I think that they will right to my hub. They come off a late modal Isuzu step van that has the same 6 on 8and ¾ bolt 22.5 bud wheels as my truck. This will be a new section in my truck build soon. I will add more on the donor vehicle as soon as I talk with the mechanic at the laundry that uses these step vans. | | |
#71236 02/05/2007 6:13 PM | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | Looks great OlBlue!! Having worked with AutoCAD and plasma tables for 20 years - and making drawings for water cutting for about 6 - I appreciate your work. Thanks for posting your progress. What truck exactly are you working on? Thanks
Professional Novice
#71237 02/05/2007 6:58 PM | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I wish I had that AutoCAD experience. I carve stuff out of wood and look for a machinist who can copy it for me. | | |
#71238 02/07/2007 9:45 PM | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Outstanding. Looks like you are one your way with the brake conversion. What about bearings? Were you able to solve the conversion from ball to rollers? Have I missed something? | | |
#71239 02/10/2007 12:17 AM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Oops, I've been really busy with my business for the last couple of weeks and haven't checked in here! \'55 2nd series 3/4 ton. Same front hubs used on 3/4 and 1 ton, \'53 - \'59. I bought a set of replacement roller bearings from Jim Carter. Very expensive no matter where you buy them but this truck is one of those "well I did this, this and this so I might as well do this too!" I have a '38 1-1/2 ton stashed in the back of my shop waiting for me to get done with a couple of other projects. I see the parts book lists the same spindle for '37-42 utility (what I have) as well as 46-50 3/4, 1, and 1-1/2 ton and 51-52 3/4 & 1 tons. It does have a note that on the earliest and latest application that you need to open up the chamfer on the flange plate pilot hole. Looks like they went to a different bearing cone when using the part in replacement service. When I get some time, I'll make a few preliminary measurements to see how different they are from the later ones. I actually have a completed mockup using the new brackets done and everything fits just like it's supposed to.
#71240 02/22/2007 2:46 AM | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Hey OlBlue, I've been out of town for awhile and haven't been near a computer. This has been an upgrade that a great many folks here have been wanting to do so, I think there would be a market for the design of those mounting plates. Well, at least a market of one anyways!!! Thanks for the post, Skip | | |
#71241 07/16/2007 7:09 PM | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | OlBlue Did you get this done yet????? Good luck Frank
Professional Novice
| | | | | Joined: Feb 2000 Posts: 120 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 120 | Thanks for the great info on the Disc Brakes...any updates or new pictures ? 1954 44001954 3800Jim D. '41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck '54 Chevy 3800 Dump........New Truck! '54 Chevy 4400 flatbed/dump, Gone to my brother-in-law '13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles '01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
| | | | | Joined: Nov 2010 Posts: 4 New Guy | | New Guy Joined: Nov 2010 Posts: 4 | Did you ever finish your project? I am looking for ANY solution to put Disc on the front of my 1950 3/4ton
1950 3600 Advance Design 1996 Restoration with flat bed Current in work: Disc Brakes, NV4500 5 Speed, Late model seats, Bed rebuild Future: Fuel Injected/Turbocharged 235
| | | | | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | OlBlue's latest post was Jan 6, 2011 - only 2 weeks ago, so he's still active. I wonder if he ever got that done too. I'm still interested for my 50 3600. Somebody should PM him.
Professional Novice
| | | | | Joined: Nov 2012 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 29 | I've been searching the site for a way to upgrade to disc brakes on my 38 1-1/2 ton. This has been the most interesting post I have found thus far. It seems to be a bit unclear as to what truck/ year this is going on. Can anyone clarify this? In Griggs post, the suggestion is to shorten a modern axle. I'm not sure I want to go that far, as I don't plan on hauling loads with the old girl. My hope is to find a bolt on rotor that matches.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | While I have shortened some axles and it does work it's not simple.... Another I think better way to go about it is adapt newer spindles complete with the related disc brake components to an original axle beam. This can work great and works better on dual wheel trucks than single, but won't work in all cases because of the measuremnts, you need to check. Here's the info. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=725027#Post725027Grigg | | |
